relicshunter
I am trying to install a new water pump on a 1976 35 hp evinrude and can find no info on which way the key goes. Other years it is real simple, 76's have a weird shaped key and the book says nothing. It was in with the square part toward the impeller and was worn away by the metal base plate. It looked like this beat up, scored key may have been what chewed up the impeller. I pulled apart another 1976 parts motor and found the key in the same way. I tried and tried to put it in the same way to no avail. I could with slight resistance install the impeller with the square toward the drive shaft and the curved part in the slot of the impeller. It makes sense that the impeller slides onto the curved edge and into place. So do both motors have it installed wrong?
http://www.marineengine.com/newparts/part_details.php?pnum=OMC0317078
Please help. The water pump catastrophically failed while out scalloping and blew the head gasket with it. I don't need a repeat of that.
