I haven't done this before so I want to get it right before I start. Have watched lots of videos, read this forum and now I have what seems a contradiction in the service Mercury manual
The Mercury service manual states:
Disassembly of Lower Unit
Shift engine into forward gear - OK
Assembly
Position shift block in forward gear position - OK
Shift gear housing into neutral position. Propeller shaft will rotate freely in either direction. -Why back into neutral? Is it to allow installation of new water pump impeller in housing? Do I do this by turning the shift shaft end on lower unit?
Then later during installation it says:
Shift gear housing into forward gear position. In forward gear the gear housing will ratchet when propeller shaft is turned clockwise and resistance will be felt when propeller shaft is rotated counterclockwise
NOTE: If, while performing Step 11, the drive shaft splines will not align with the crankshaft splines, place
a propeller onto propeller shaft and turn it counterclockwise as the gear housing is being pushed toward
drive shaft housing -But if in forward gear how can I turn it counterclockwise?
Can anyone help?
Assembly
Can anyone help?
