snocat_trf
I have been fighting this outdrive for a year!!!! ARRRGGGHHH!!!
I am at my wits end with this thing, I can operate the switch to lift the motor and all i get is about a 1/2" of lift out of the lower unit, if I put slight tension on the lower unit and have someone operate the dash switch it goes up just fine. It also goes down easliy.
The only thing I can think of is that there might be too much clearance in the gimbal pivots to allow for the lower unit to pivor properly.
It seems like there is some bind in the clutch pack so i was wondering if I should find a second clutch pack as a donor to try turning down the diameters to fit in a set of needle bearings for it to rotate on.
Things I have checked and replaced:
Snocat_trf
- rebuilt clutch pack multiple times. tried 30 wt oil and greasing as well as regrooving clutch plates and wearing in to steel plates
- replaced lift motor, (I have 3 of them)
- replaced solenoids as well as cleaning contacts.
- replaced "ball" fuse and upgraded to a 50A plug in style
- direct grounded lift motor to battery
- direct wired solenoids to battery
- removed gimbal caps and regreased and replaced cautiously to avoid any bind
- removed clutch pack to manually to ensure lower unit pivots with no bind
- replaced battery as well as wiring in two batteries in parallel to ensure enough amperage to operate motor
- segment gear and drive gear
- machined out a bronze bushing for clutch pack shaft to tighten up clearances to prevent bind.
- greased everything in the lift mechanism to make sure there is slip on all surfaces
- motor goes forward and reverse fine while not under a load.
Snocat_trf
