Eaglefixer
I was out of the lake all last week and it ran fine then as we were getting ready to move to a different spot on lake the motor fired right up then quit!!. It's a 1985 75 hp mercury that wont start but will turn over just fine. I've checked gas and its good. i found a few spots in the wiring coming found the ignition switch that had the insulation cracked but wires seemed to be ok. Got a spark tester and it appears there is no spark at all 4 plugs.
Change out ignition switch and changed battery cable ends and cleaned and charged the battery and it turns over a whole lot better but still no spark!!!!!!!
Well may have found my problem. I found some broken/bare wires that are coming out of the stator under the flywheel. Can't get to them yet but i can see just them barely. any idea what to check next?
Motor is a 1985 Mercury 75 Hp 4 cylinder Serial #0A169243
Steve
Steve
