Bought this boat not too long ago and it idles a little rough. Also when try to go full throttle it surges until it finally runs wide open. Guy that I bought it from said the motor had been gone through a couple years ago. All carb gaskets look pretty new. So I pulled the carb all apart and made sure float was adjusted properly blew out with air and reassembled everything. Changed old spark plugs and noticed one had some water on it when I pulled them after running it for the first time since changing them. I pulled the plate off where the spark plugs screw into and the gasket is in ok shape but wasn’t sure where water would be getting in. Noticed that there was some water between plate and gasket. Any help would be greatly appreciated. Thanks
Olaf
Olaf
