Hey guys,
I was wondering if someone might be able to help with a couple questions I have about this remote/motor combo posted in the title.
Basically I Replaced the power pack on this motor a while back because the motor would die after about 10 minutes or so of running, and when I tested it I was not getting a spark. After replacing it, the motor ran perfect for hours when I next used it, but I could not get any higher than idle speed. I initially thought it was the cable, but upon inspection found the gearing in the remote control was busted. someone I knew said they had a remote control unit that would work with my boat that I could get for $20, so I bought it.
The new control unit was an OMC (year 2001) which was different then my original unit (don't remember what the first one was). What I noticed when I was hard wiring the new control unit in, was that there was no light brown and light gray wire coming from control unit to connect to the wiring harness of the motor, but all the other wires seemed to match up.
My questions are, what are the light gray and light brown wire going to the motor used for? And, will this remote control work with my motor?
The reason I ask is that since I put the new remote control in, the engine will only start occasionally and instantly dies after about 1-2 seconds. Often I have to try starting it a ton of times before it fires.
When trying to start it a few times I tested the plugs to see if they were firing but could not get a spark. I know it has to be sparking at least sometimes though since it occasionally fires up for a second. My thoughts were that the kill switch/key switch are bad since the are the same piece, and since it ran fine prior to replacing the control.
If my OMC control and motor should work together, any thoughts on what the problem may be would be greatly appreciated.
Thanks All!
Thanks All!
