75 99 evinrude no revs underload
ogre84
my 9.9 only have partial revs
my 9.9 only have partial revs when under load but revs fine in neutral i changed the points and condensers and gaped the to.020(i think) can anybody help me out i would also lke some advise on the mixture screw on the carb
"(Point Setting Of Magnet
"(Point Setting Of Magneto Models)
(J. Reeves)
Set the points as follows. Have the flywheel key aligned with the fiber rubber portion of the ignition points. Adjust the gap so that a .020 gauge will pass thru but a .022 will not. Should there be any question of the points being dirty (touching the contact with your finger would cause them to be dirty), clean them with a small brush and acetone or lacquer thinner.
NOTE: Should the operating cam have a small portion on it with the word "SET" imprinted, align this portion with the fiber rubbing portion instead of the flywheel key.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note 1: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
Note 2: If the engine should be a three (3) cylinder engine with three (3) carburetors, start the adjustment sequence with the center carburetor.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
"It may be a good idea to remo
"It may be a good idea to remove, clean, and rebuild that carburetor.
A engine can rev shy high in neutral.... on one cylinder BUT that's inviting a thrown rod!
Your explanation indicates a fouled carburetor."
"I would fire it up and try re
"I would fire it up and try removing the spark plug boot from each cylinder to determine if both are indeed firing. If the motor dies when a single boot is removed, you know the other cylinder was never firing and the loss of it is causing your low RPMs under load. If you have lost a cylinder, then you can eliminate the carburetor and fuel pump/line as the culprit and most likely lead you in the direction of coils, points and plug wires. On the other hand, if both cylinders are firing then it may very well be a fuel delivery issue.
The real beauty is it's an easy test to perform. Use insulated pliers to remove a plug boot from a running motor. The voltage these motor build up can shock you right through the boot insulation."
