Hi and thank you in advance
I have a 115hp Johnson it has no power
if you give it gas it will go but shortly after will bog down and sputter.
I got got it a few months ago and it ran ok but seamed to have a sputter. I called a local shop and had them tune it up and check everything out. Water pump ext. they said everything was great. Took it out few weeks later and killed the battery trying to start it. Got new battery and got it started and it ran worse then before I had it worked on. It sputters and has power loss. I cleaned the screen on fuel pump and ran new gas lines to carbs.
I had had it out today and it's worse then before.
Thinking of getting rebuild kit for the carbs?
I'm worried it will die when I take my 3 year old out fishing.
