74L MPI fogging
rackey
"I'm looking for the specs
"I'm looking for the specs for the recommended fogging procedure for MPI engines. I know that you run a mixture of fuel, stabilizer, and 2 cycle oil, but don't know the ratio or time frame."
"2 cycle oil" ??? Use
"2 cycle oil" ??? Use engine "fogging oil". Treat the fuel with STABIL or a similar product and THEN top off the tank. Run the engine on ear muffs until it reaches oper. temp. and continue for 10 more minutes. Lube the gimbal bearing w/the appropriate bearing grease while it idles.
Remove the flame arrestor and increase the RPMs to 1500 - 2000 or enough to keep the engine from stalling as you spray the fogging oil into the throttle body while holding it wide open for about 20-30 seconds until a good blue smoke comes out the exhaust. Turn the engine off and then stop spraying. I DON'T KILL MY ENGINE WITH FOGGING OIL SINCE OIL DOES NOT COMPRESS. You are done fogging. Perform the rest of the winterizing procedures; drain the block and heads and add antifreeze. Search the site for the procedures.
"Guy:
I doubt if you could
"Guy:
I doubt if you could get THAT much fogger oil in a cylinder to hydraulic anything, but good point. I spray the fogger in 'on the starter'--why let it all burn off with the motor running?
Jeff"
NO FOGGING OIL and any MPI mot
NO FOGGING OIL and any MPI motors
you need to make the merc cocktail they say in the factory manual
if you need it email me
"My Mercruiser manual say mixt
"My Mercruiser manual say mixture of: 5 gal of gas, 5 oz fuel system treatment and stablizer, 2 qts of Premium 2 cycle TC-W3 outboard oil.
How do you connect this mix to the fuel system?"
"I stand corrected!<[img]"http
"I stand corrected!
"the reason for the cocktail i
"the reason for the cocktail is to lubricate the injectors for the layup, as just in time states, you need an aux tank, the little 5 gal outboard tank is what i use, install your fuel pickup line from the tank and run, I usually 10 to 15 mins, then dump the rest of fuel into tank. just my 2 cents"
