"The 7.4 is fuel injected thro
"The 7.4 is fuel injected through the throttle body. I have replace all the fuel filters and keep the fuel maintained with Staybil. The other engine runs fine but for some reason the port engine will not throttle past 3000 rpm. Once you reach that rpm the engine no longer runs smooth and will no longer keep up with the other engine.. I have replaced the plugs, plug wires, dist. cap and button, clean air filter. Nothing has worked. Is there a sensor that might be throttling back this engine. I did also check with a timing light to make sure the engine advances when reved. It is advancing.
I read a few things about the anti siphon valve but cant find it. Any advice would be great!!"
