74 EVINRUDE STARFLITE 85 HP
D
DAYVYD SKLBA
Guest
" I HAVE THIS 85 HP EVINRUDE O
" I HAVE THIS 85 HP EVINRUDE OUT BOARD. WHEN I CRANK IT AT HOME IT RUNS KINDA,IT SPITS ALOT. THATS ONE PROBLEM. THE OTHER PROBLEM IS WHEN I PUT IT IN THE WATER AND PUT IT IN GEAR IT DIES EVERYTIME. i CHECKED THE PLUGS THEY ARE GOOD AND TOOK THE CARB. OFF AND CLEANED THAT GOOD. COULD IT BE TIMING THAT IS MAKING RUN SO ROUGH OR JUST THE IDLE TO LOW. "
The timing is fixed. Check co
The timing is fixed. Check compression and spark at EACH cylinder (5/16" gap)Stalling can be an indication of major problems.
