Brandon1976
Have a 74 Johnson 9.9. What is not getting water change the impeller housing everything for the pump. Still was not getting water remove the power head change the grommet cleaned out the water opening. Blow air and water through the head and put water in it went in one side came out the other. Put it all back together still not getting water. Change the head gasket also and the water gasket for the thermostat motor is running hot any thoughts
Plenty of water in the bucket its a 50 gallon above the plate
