TheCanMan629
I'm currently in process of diagnosing a problem with a 1974 Merury 110 9.8 hp- It has good spark (off casing and spark tester) Has newly rebuilt carb. I've done both a wet and dry compression test, both of which yielded 60psi from 6-10 pulls. The only other thing I could imagine is the reeds are bad. Any other suggestions before I split the casing to rebuild it?
Thanks in advance!
Thanks in advance!
