masterknowitall
I'm having difficulty with reverse. On the controller there is a detent position for forward and another for reverse. I can't shift into reverse with controller but when I shift into reverse manually with cable removed my prop turns in reverse when moving flywheel. Still trying to figure out if I have a cable adjustment issue (cable doesn't seem to push slider back far enough) or something deeper in the lower end. When I shift manually into reverse, with cable disconnected, the prop doesn't ratchet in the forward direction when turning prop by hand. Nothing in my manual addresses the controller, cable adjustment and only vague description about where to position the cam when reinstalling lower end and nothing about the prop ratcheting in forward (it does) and not ratcheting in reverse. Any advise would be greatly appreciated and I'll answer any questions as quickly as I can. Thanks.
