73 mercury 50hp bogging down
killertrance
"hi,ive been experiencing runn
"hi,ive been experiencing running probs with my engine,its a fourcylinder,thunderbolt ignition 50hp.it starts and runs in neutral fine,reving perfectly,ticks over imidiately,but put in under load in the water and it just plods,if i raise the throttle i just get a load of induction noise and nothing else,it just plods.ive replaced the plugs,new fuel pump,cleaned carbs three times and still this happens,its getting very annoying.can anyone shed some light???????my engine has a distributor and is the thunderbolt ignition,could the trigger box be faulty or the distributor....thanx for any advice,regards,jeff"
Hook up a timing light and che
Hook up a timing light and check that you have a spark at each cylinder. Then check compression. When carburetors were off did you look at reed valves??
