73 evinrude 65hp
merc1877
Ive got 73 evinrude 65hp with
Ive got 73 evinrude 65hp with a short shaft and i need a long shaft motor for my boat it currently has a merc 115 tower of power without the power has a bad piston rod or wrist pin or something bad like that broke so i want to put my 65 on but i need to know what other years are compatible on the lower units and if anyone has one? thanks
a friend gave me a starcraft w
a friend gave me a starcraft with the tower of no power and he also gave me this evinrude and said there wasnt anything wrong with it it just had to short of a shaft for the boat and i would really like to get this boat on the water since i just put a new deck and everything in it and fixed it up
is it the mid section that mak
is it the mid section that makes it longer could i get that and a longer shaft and put in to make it the 3 or 4 inches i need to reach the bottom of the boat
you need the mid and the lower
you need the mid and the lower unit also if you got a lower unit you have to change the drive shaft the drie shaft is sho
rter on the short
i have a good lower unit and m
i have a good lower unit and mid section just its to short so i can get a longer mid section and a longer drive shaft and it would be fine what years and horsepowers are compatible with it
"here you go if you cant doo i
"here you go if you cant doo it your se
lf"
