I have been all over this learning as much as I can and refuse to give up on the outboard 65ESL72. I installed new oil pump as old one was bad cracked at screen area took apart with manual step by step tested solenoids 6.0 ohms both green and blue wires then put back together with new oil pump and seals new water pump gaskets then pressure tested everything seem great not to hard with manual then installed lower unit. I tested shift wires engine running in neutral green wire has 12volts.. in reverse both blue and green 12volts.. forward no power at all on blue or green wires great right ..nope ..no forward gear works great in neutral and reverse but nothing in forward ..turn motor off spin prop I have forward of course defaults in forward gear motor off ..For some reason I don't have forward I read the manual up and down read posts on here still stumped. Read the Joe Reeves write up on how it works and cant figure out why no forward engine running. please help tx
