CarMech1969
Hello all,
I'm back here again, hoping to obtain some advice.
My '72, which I recently acquired, has developed a strange sort of problem.
What happens is, if I run the motor at WOT for an extended period, after a given time, the motor will start to decelerate on it's own, lose power, and finally cut out.
It doesn't seem to do this on lower throttle openings, however.
If I immediately pull the cover after a high-speed run, a bit of smoke can be seen rising off the cylinder head. Overheating perhaps?
During a high speed run, just prior to it quitting, the water peeing out seems to reduce in volume.
The engine will start and run fine again if it's left to cool down awhile.
A friend of mine had a Mercury 7.5 with the exact same symptoms, but I forget what the fix was.
Anyhow, I pulled the water pump and everything looks OK. The impeller feels soft and pliable, with no signs of cracking.
Pulled out the thermostat, and it appeared as though water had been circulating.
If you guys could suggest as to what to do next, I would be very thankful for it.
Happy boating, mates!
