I recently purchased a long stored fresh water only 1972 Evinrude 50 hp model 50273C.
We changed the water pump as a result of the overheat alarm sounding after 5 minutes at idle on initial start up. It still sounded the alarm after the replacement of the pump.
Below is a summary of the troubleshooting to date as posted on http://forums.iboats.com/showthread.php?t=379974.
I pulled the water jacket cover on the back and changed the thermostat which when tested did not open at the correct temperature. I also tested the replacement thermostat which functioned correctly. In addition, I replaced the "poppit" valve grommet. The valve was ok.
The unit still sounds the alarm. A temperature check of the head at the time it sounds the alarm (around 4 to 5 minutes at idle on the muffs) shows the temp to be 102 deg. Centigrade (215 deg. Farenheit) which per my clymer manual is the appropriate temp for the sensor to close and power the alarm horn.
Just prior to the alarm the water flow from the hub increases and steams. There is no tell tale trace on this model engine. As a result I "think" the pump is functioning correctly. I do not see any water coming from the upper vents at the top of the exhaust housing just below the engine.
My question is NOW WHAT??? Could it possibly be that this engine will not run on ear muffs? As I recall I had a similar year model about 30 years ago and ran it on muffs but I'm not certain.
Can I pull the head without removing the water jacket cover to check the cooling passages? Just where do the cooling passages run?
If anyone has a coolant flow diagram for this engine I would sure be grateful if they would post it for me.
Update
Thanks for the replies guys. I'll try removing the water jacket plate and the thermostat again... (it's a PIA). I do note that I have yet to get any water out of the upper vents on the exhaust housing. Is that significant?
Also, in other threads there is mention of water deflectors perhaps being the problem. I can't locate that item on any evinrude parts list. Does anyone know the evinrude teminology for those parts or even if they are applicable on this model engine?
I will say that the top of the head and the passages for the pressure relief valve and the thermostat were nice and clean when I had it off and showed no evidence of corrosion.
Update
I ran the engine with the lower unit submerged up to about 1/2" below the cavitation plate. Still overheating.
I again removed the cylinder head cover to confirm the thermostat in place and it was so.
I removed the thermostat and the pressure relief valve and started the engine on the hose muffs. As expected it still overheats.
BUT NO WATER IS PUMPED UP TO AND OUT OF THE THERMOSTAT OR PRESSURE RELIEF HOLES.
Keep in mind that the water pump impeller was replaced by a local shop prior to my first start up of this old engine. An outboard salvage yard here locally with a grizzled ole hand who's been at this for 30+ years says that if the impeller plate were installed upside down the pump would move some water but not enough to cool the engine.
The shop that replaced the water pump states that the impeller was not broken into pieces but had a rigid set to the blades so it was replaced. They insist that they could not have installed the impeller plate upside down since when on the muffs if the engine is reved above idle the pumps sucks in the overflow from the muffs. They say that the problem is perhaps the gasket or o-ring where the water tube enters the bottom of the engine.
In going over the Evinrude parts list for this engine I see no such gasket.
HELP HELP HELP - I'm sinking here!
Steve
Update
Update
Steve
