Took the boat out for it's maiden voyage with the new floor, carpet, and seats on Saturday. I replaced the #coil first as I've been having issues with the wire arcing to the motor and making it hard to start. She ran like a top all day long. Burned about four gallons of fuel pushing my light aluminum boat all over the Puget sound. Got it home, hooked it to the muffs, fired it up and disconnected fuel line from the motor to let it run the fuel out while pumping fresh water through the engine. Then I rinsed the boat off really good.
Yesterday, I dragged it two hours out to Port Townsend hoping for Halibut and Lingcod. Again, she ran like a top at first. About three miles from the harbor, while running at WOT, she died. Not a slow sputtering death either. I had one cylinder that fired a few times after the other two cut out but I doubt it fired more than two or three times. It was fairly sudden. Tried cranking it back up, nothing. Checked fuel supply, plenty of fuel, pulled the hose off the motor and checked flow, no blockage.pulled the filter cap and checked flow there too. No issues. Tried cranking her again after manhandling the primer bulb a bit and she coughed a bit. After about an hour tinkering while drifting slowly back towards the US side, I got her running by steadily forcing fuel through with the primer bulb. This was tricky as I either had it just right, or I flooded the engine. My buddy drove while I sat in the back pumping away and we were able to get her back in. Just before we got back into the marina, I stopped pumping the bulb to see if maybe it was a blockage that I had worked out by then. She ran fine for about 30 seconds and then suddenly died again. I couldn't get restarted this time so I ended up paddling it back into the marina.
Pretty sure that the symptoms screamed fuel pump, so I pulled it off and tore it apart (It's the old original one that was discontinued a long time ago). Didn't anything apparently wrong with it. The diaphragm looked wore out, but I think I found one spot where it was leaking by the upper spring. I ordered the replacement pump and it should hopefully arrive this week. My question to everyone is this: Anything else that I may have overlooked? The vacuum line appears to be in great shape and none of the fuel lines are leaking. I'm fairly certain that the new fuel pump will fix her right up, just anted to bounce that off of you all.
