Hi Joe and thanks for the rep
Hi Joe and thanks for the replies again and for the "new conversation"tip. I'm new at this board and still feeling my way around. Well as you said earlier to check the solenoids once the unit is "benched" I did that and the readings haven't changed. The units both neutral and reverse were both working fine before this episode happened and I must tell you I had another chap tell me the same thing that they should be fine once the shaft problem is rectified. He had also said that applying 12v to the solenoids with the unit on the bench I should be able to hear the units clunking...I don't. This chap rebuils o/b for a living but I will check these in more detail. I also understand that these shafts are no longer available anymore or they had taken them out of the price catalogue. Is this true and my only hope would be if anyone will have a used or an extra in stock somewhere? This shaft is definately longer than 20" but I can't tell you if it's the worm style at the bottom or if the top spline would be fine or coarse. Can you let me know what this engine should have in it and how much these things are worth. What stock do you have? New or used? Thanks again Joe....Bruno
