razorbackgreg
Either the water pump failed or thermo failed on my 18Hp Evinrude while on the lake. Moving along at 3/4 throttle engine slowed and died. Smoke coming from under cowling and the engine paint was coming off. Wouldn't restart. Compression check showed 30 and 60. Removed head and the top piston had material burned from the ridge in the middle. Walls in both cylinders showed some scoring. How bad does the scoring have to be to require a reboring and then oversize pistons? It looks like oversize pistons for this engine are no longer available. My dad gave me this motor and I would like to have it repaired if it is not to unreasonable. It ran like a champ until this happened.
