palmer_df0130
Hi y'all!! I am looking at possibly buying the above mentioned motor, but it is missing the gear selector lever itself and also the assembly does not seemed to be engaged on the gear selector shaft that goes into the lower unit. the current owner bought it as it is and never has had it running since he bought 3-4 months ago but claims the owner before him said it ran fine before the gear on the end of the selector switch broke or fell off. It seems to be stuck in gear and I would love to be able to get this motor started to see if it runs good first to even consider buying it and also would like to know how hard of a project would it be to replace the whole gear selector assembly if I can even find one. Also the bottom part of the skeg(I think that's what its called) was broken off at one point and is bolted in place by 2 flat straps of metal and bolts. How can I get it into neutral to start it as it is now? Is this year motor a good one, strong with little known problems? How much is it worth as is? Thanks in advance for any help.
