70wellcraft
My 71 Johnson 100HP V4 will run great for the 1st 15 minutes or so after launch but then like a switch, it will only run on like 2 cylinders. Then I let it set in the water for 20 mins and its running good as new for another 10 mins or so. Its very repeatable. I have tried swapping coils and MSD spark units (I converted it from the stock box 3 yrs ago) but still same problem. I suspect the following;
- The motor has 2 sets of points. Maybe one set is heating up causing those cylinders to not spark.
- There is a thermo switch assembly that is for some reason jumpered to the Amplifier on the terminal block. This switch controls choke soleniod. This is per the stock schematic. could this switch cause this issue?
- There is a Temperature switch that turns the overheat horn on when engine gets hot. Could this cause the problem?
Thanks for any input!
