"I got the motor to turn over
"I got the motor to turn over with the key after going through all my wireing, I had "fogger" in the carb's and it started up for about 1 min then shut down, I removed the carbs so I can clean them, I now have the motor's block (where the carbs go) faceing the cieling and I put about a half of a pint into each opening so the inside is well loubed, when I put the carbs back on the block, should I remove the plugs and give the oil/gas mixure a chance to run through the motor or just fire it up?....sorry if my questions seem stupid, but I just dont want to tare it up...Thank you all for your patiences and answers."
