71 100 HPevinrude starts, heats up, linkage won't move
danevin
3/31/2019 Flywheel gets hot after 15 minutes and linkage wont move to restart; changed impeller and thermostats
WHAT ELSE IS THERE?
Flywheels do get warm from magnetic flux as part of recharging the battery.----Remove flywheel and all the ignition bits to check why timer base sticks.
Flywheels do get warm from magnetic flux as part of recharging the battery.----Remove flywheel and all the ignition bits to check why timer base sticks. Did all that-the shifting linkage and timing siezes up.YOu can't get the starting position in the right place cause its stuck and won't move.
Did all that-the shifting linkage and timing siezes uup; you cant get the starting position in the right place cause its stuck and won't move.
No shift linkage on this motor.-----Take the lever on the side of the block apart.-------It is not assembled correctly.
