"Greeting All I am new here bu
"Greeting All I am new here but have been reading your forums for some time.... now for the Question.. I have a 1984 ( I think) 70HP 3 cyl Mercury OB.. The warning horn sounds after running it for a little while, maybe after 5 to 10 minutes of running,, horn sounds while running at full throttle or down to idle... while trolling it may sound or not or maybe just a quick beep,, if it does I vary the rpms a couple of hundred rpms it quits some times,, I changed the impeller thinking it was worn out but it wasn't... the water coming out the squirter in the back is basically lake water temp NOT hot???? I took the thermostat out and put it in a pan of water and warrmed it up and it started to open slowly untill fully open..the oil Inj. resivoir is full of oil.. I have a water PSI gauge on the dash it reads 11 psi trolling and 11 to 15 running... do you think it may be the module??? the module is the most expensive of the parts I think... I would think temp related as it waits untill warmed up.... any ideas would be much appreciated..
Skip"
Skip"
