70hp Johnson no spark
bowfish2000
I searched through the threads but did not find anything related to my issue.
I have a 70hp Johnson J70TLCEM outboard with no spark. I've checked for spark with plug, spark tester and old fashion way with screwdriver.
I have replaced the CDI box, ohm the stator (it ohms within range 1.5), checked wiring, bypassed the kill switch, pulled the flywheel, cleaned flywheel and visual check stator, no oily gunk oozing out.still no spark.
Kinda at a loss now, what else should I check?
The 1.5 ohm reading is on the yellow wires ?-----What is the reading on the brown wires ?----What is the reading on one brown wire to ground ?-----What are the readings on the trigger wires ?
