"I have just fired up my '
"I have just fired up my '77 70HP after a complete rebuild. It fired second crank and idled great. I have the engine in a tank of water filled to around the top of the water pump (new impeller fitted). Water came out of the tell tale (tapped into the exhaust manifold) initialy then stopped after a few minutes. Plenty of water comes out of the two holes in the leg below the exhaust adapter. I ran the engine fo approx 20 mins at a fast idle. The temp of the water coming from the holes in the leg was approx 120 degrees. The head was warm/hot and the crank case on No.1 piston was hot - you could hold your finger on it for 5 seconds before it was too hot!. The bottom centre stat cover bolt has a leak (will silicone it tomorrow) with a fine jet of water, could this cause the lack of tell tale water? When I stop & restart initially there is a weak flow of water from the tell tale, then it stops. How long does it take for the engine to get to operating temp? The cylinder head cover was warmish, since I guess the stat had not opened! Have not taken it on the water yet since I want the cooling to be right. I am sure that it has not over heated since the head and cylinder case are not hot enough to touch. Any help is appreciated."
