Hey everybody,
First time posting, and new to boating so here goes!
I've got a Mercury 70HP 2 Stroke 3 Cylinder motor from the late 70s/early80s and the thing ran great. One day, it was having trouble starting. I did some tests for compression, spark and fuel and everything *seemed* to be OK. Fast forward and it turns out the spark was too weak which is why it was only starting intermittently at best. I took off the flywheel cover only to uncover the stator wires were completed rotted. I replaced the stator, and now she finally coughs again. The problem is when I installed the stator, I had to install it backwards (180 degrees) off because the wires for the new stator were way too short. Instead of cutting and splicing, I installed it backwards just to see whether I would get a nice strong spark again. Motor will now start up, but it almost sounds as if the timing is off. Now I'm wondering whether I should go back in there, and splice the cables to make them longer in order to install the stator the "correct" way. Can anyone confirm whether installing the stator in a different direction could cause a timing issue? I'm 100% sure I didn't mess with the timing because I didn't have to use a flywheel puller to remove the flywheel. I have the red flywheel cover with 6 or 8 bolts that can be removed in order to gain access.
Here's the problem.... when I was diagnosing the boat, I initially had spark, but in fact it was very weak because of the stator failing. So I thought it would be best to do a carb clean since this was a boat motor that was new to me and I was having starting issues. Carbs have been rebuilt although the carbs weren't really all dirty to begin with.
Now I'm wondering what to do first. Should I a) Keep fiddling with the carbs because I may have done something wrong or b) Open up the flywheel, extend the stator wires, and reinstall the stator as it was when I removed it?
Thanks in advance for your help
