" I have a 70' Evinrude 11
" I have a 70' Evinrude 115 (model # 115083D) that seems to be losing it's spark from 2600rpm to full throttle. With an inductive timing light connected to any one of the plug wires, the flashes begin to get eratic(few and far between) from part to full throttle. I have cleaned,checked and double checked the fuel system, including the carbs(H/S jets,float level,and S/S needle adj.),and a new fuel pump.I also cleaned the distributor head and rotor and checked for cracks.Wires check out fine,as well as new plugs gapped at .035. Compression is 123-125 psi on all four cyl's. When I tested the ign. coil output I got nothing,no matter how close to ground I put the wire. Could this be the problem? The only tester I have is a volt ohm meter. Can it be used to check the pulse pack,rectifier,ign.coil,and the other sealed box over the pulse pack? Thanks in advance for any help! "
