I have a Nissan 70a that fires up and initially runs great from bottom to top. Then after shutting off the engine it will fire right back up, but when I go to engage into drive it has a major hesitation and will often die. Working the engagement back and forth for a period of time will typically get the engine to fire up and run.
So I pulled the carbs and soaked myself. Same problem. Took to a boat shop and had them clean the carbs. Same problem.
Where do I go from here?
Thanks for any and all advice!
