A
AlabamaRan
Guest
" Hey Joe,
I got one more q
" Hey Joe,
I got one more question about my 70 model 9.5 Johnson. Could you tell me,step-by-step, how to adjust the low speed jet on this carb. It has a R/L knob on the front that appears to turn the cable to the carb, and also a knob on the right near the tiller for low idle or something. Then it has a screw on the front of the carb with a spring on it.
The little motor will sometimes crank and run a bit before dying, then I usually have to wait a long while until it will crank again. Is there a certain procedure for cranking this motor?
I prime the bulb, choke it, pull until it fires, let it run a little (if it keeps going), then push choke in half-way(usually dead by now), then push ckoke in all the way, throttle a little, shift and go. Used to work, but rarely stays going long enough to get to the last steps.
Like I said earlier, I am an awful mechanic, and one who don't have a manual for this engine. Could you tell me how to set this carb up so that I can make adjustments, then how to adjust it so it will:
(1)Crank and stay running long enough make adjustments
(2)Fine tune the adjustments to make it run at its best
I am sure this can be difficult without your being able to see this motor and hear it try to run, but I appreciate your expertise and thank you for sharing it with us. By the way, don't you ever get tired of hearing us whine to you about our problems (smile)? Thanks again Joe and all the others who share their knowledge. "
I got one more q
" Hey Joe,
