I have a 70 hp Johnson that I put on a 20 pontoon. When operating for long periods of time at full throttle, the overheat horn will go off. If I slow back to an idle it will turn off in just a few seconds. I have replaced the water pump and the thermostat has been removed by previous owner but I have a new one to put into place. I was told by the marine shop that removing the thermostat would not make any difference except in cold water because the engine would never heat up enough to run smoothly.
