W
WardHenry
Guest
"I have a 70hp around 1991 2 w
"I have a 70hp around 1991 2 wire with 2 hydraulic lines comming from the base of the trim motor housing. I have a new motor and housing to install but I read that when the motor is down the trim system is under pressure. I have read that there isnt a manual release on the 70 hp. I have read you can loosen the hydraulic lines to release pressure but I was wondering why you couldnt just carefully loosen the filler cap or loosen the 4 bolts holding the pump housing to the base. After removing the 4 bolts and swapping the new one, adding fluid at the filler and cap and bleeding is what I was wanting to do, or do I have to get the motor in the up position first? Sorry to be so winded but I wanted to give as much info as I could. Thanks for all replys."
