"Hi everyone I have an envinru
"Hi everyone I have an envinrude 70hp Model 70673D serial 71185. I got this motor purring after i did the carbs fuel pump and all fuel lines. Now i started it on a stand with muffs. This motor has 2 1/2 holes side by side futher up the back of the motor water tricles out of them kind of sputs out is that normal i dont see any pee hole and the engine runs great and doesent overheat. the guy that gave it to me said the bottom end was rebuilt not o long ago and he always remembers it doing that, could some one tell me if its normal? also i would like to change out the entire water pump can i just remove the lower end bolts and replace or are thesre any little tricks like putting the gear in reverse or anything. Also does this motor have a thermostat Thanks"
