bearpast50
Presently has 13 1/4 X 17 alum
Presently has 13 1/4 X 17 aluminium prop. The manual says the motor should be reving between 5200 and 5800rpms. The factory tach is registering 5000rpm at wide open throttle. Should I be looking at a different prop to raise the engine rpms? Can I also slow the speed of the boat as it does not troll down all that well?Is it possible to do both with a prop change?
