70 hp 3 clyl envirude older model80bs
M
mike nano
Guest
bought old boston whaler maunt
bought old boston whaler mauntaulk?65-70 motor is 3cyl 70 evinrude dont think motor that old. starts right up i idle it fo a while put into gear planes right away.sometimes after stopping go to throttle up it wont go past slow speed can push throttle up but speed stays same like it wont go to next level first boat ever owned. is this a choke issue? throttle cable?
"What is the model number of t
"What is the model number of that engine? Plate on port transom bracket.
When in that slow running problem area and you're using a buil;t in tank, if you pump up the fuel primer bulb and the engine starts to run normally, that would indicate that the snti siphon valve at the built in fuel tank is stuck open or doesn't exist.
(Fuel Anti Siphon Valve)
(J. Reeves)
Many of the later OMC V/6 engines incorporate a fuel restriction warning via a vacuum device attached to the powerhead. If the engine overheats, or if you have a fuel restriction, the warning is the same.... a steady constant beep.
NOTE... Only the V/6 & V/8 engines have the above "Fuel Restriction Warning". The warning horn will not sound on the other models.
The fact that a engine is not overheating, but the warning horn sounds off with a constant steady beep, and that the rpms drop drastically would indicate that the engine is starving for fuel due to a fuel restriction. Check the built in fuel tank where the rubber fuel line attaches to the tank fitting. That fitting is in all probability a "Anti Siphon" valve which is notorious for sticking in a semi closed position. It will be aluminum, about 2" long, and the insides of it will consist of a spring, a ball, and a ball seat. If this valve exists, remove it, knock out those inner components which will convert it to a straight through fitting, then re-install it. Hopefully that cures the problem.
The above procedure will cure a restriction problem with the anti siphon valve as stated. BUT, it may also allow fuel to drain backwards to the fuel tank when the engine is not running (siphoning backwards) due to the fact that the carburetors/fuel pump etc are higher than the fuel tank. This condition is not an absolute as the valves in the fuel primer bulb usually prevent this backwards siphoning problem. However.... if this does take place, the cure would be to install a new anti siphon valve.
When time permits, visit my store at: http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store"
