7.4 liter operating temp?
160/170 Degrees is optimum. Anything lower decreases efficiency and could confuse your ECM/Computer into thinking your engine is just starting. This in turn will cause it to run rich. These modern fuels, ethanol blend, are designed to be used at 220 Degrees but that is not possible in the marine use. Al W.
My 89 FWC 454s also run at about 170. RWC engines have a 140* thermostat and therefore run much cooler than their closed cooling cousins.
