paul_rodgers
Hi guys I have a strange problem that I hope one of you guys can help me with. First I have rebuilt this engine everything new on inside, It is set right on in timing and starts at the turn of key. It will accelerate to about 2800-3000 rpm's and then it will sort of run into a wall and will hold that same rpm even with throttle wide open, it normally runs between 4200-4600 rpm's. But here is problem with it sitting in slip at marina and I push in the switch for throttle only it will rev past that 3000rpm's with no problem.. Is this normal? Thanks Paul
