Mikeandike757
I have a late 70s 6 HP Johnson (6R78B), that will not start no matter what I try.
When I first brought it home I was able to get it running but would only stay running WOT. I took the carb off to clean out, blow out, and replace any worn or damaged components, and after I put it together it wouldn’t fire at all. I am able to get it to start for a second with starting fluid, but no luck otherwise. I have ensured the spark plugs have spark, the fuel pump is pushing fuel (50:1) all the way to the port on the side of the carb, and the motor has compression (I have not measured it yet, getting a gauge today). Im almost certain the carb was put together correctly and have watched a million videos to double check everything is there, but there’s always a chance I messed that up considering nothing happens now.
Any help is greatly appreciated, Thank you.
