I am attempting to repair a 1998 6HP gearbox - it started sticking in forward gear - i could get it to unstick by carefully manually forcing the prop back and forth (motor off and kill switch off of course). But that no longer worked and it's now stuck in forward.
I disassembled the gearbox, and everything came apart easily until I got to the Pinion gear and the shaft/gear below it - I can't determine how to get these out - videos for larger motors show the shaft sliding out, but this seems to be stuck / jammed on mine - before applying force, is there something I'm missing?
Thanks in advance for the advice,
Tom
Tom
