6hp evinrude 1986
edwin
"I am new on boating, I just g
"I am new on boating, I just got a 15ft aluminum boat+trailer+ 6hp evinrude engine, engine turned on the first day and I let it run for a few seconds, next day, runned again with a water tank, it ran some seconds, then it stopped, since then I can not make it run, I cleaned the carburator, cleaned the piston and cylinders, checked the fuel pump(diaphragm), replaced the spark plugs, and replaced a broken cam follower(came broken when I bought the boat), but I am just out of resources, if any knows what else I can check I will appreciate, my emial is [email protected]
thanks already for any help that somebody can provide me."
"Do you have compression? Spar
"Do you have compression? Spark plugs should be Champion QL77JC4 plugs gapped at .040 . Are they?
With the spark plugs removed, the spark should jump a 7/16" gap with a hot blue lightning like flame.... a real SNAP! Does it?"
