Just replaced the water pump in my 6hp longshaft 4-stroke merc (nissan/tohatsu clone). when I came to fit the gearcase back on I ran into issues. I had it in reverse when I removed the gearcase and I tried to get the thing back together in reverse but no dice in the process I seem to have struck a problem with the shift shaft. If I turn the driveshaft clockwise then the prop shaft turns clock wise if I pull or push on the shift shaft I can't find neutral or reverse. There is a little up and down play in the shift shaft and I can rotate the shift shaft 1/2 a turn or so in either direction but I can't pick up neutral or reverse. Have I some how damaged the shift mechanism? I don't recall using any excessive force that would have broken anything?
