Chad Noben
First off.... is there anywhere online i can get torque specs? I have this motor completely tore down. The pistons looked good so im just going to re-ring it and hone the cylinders. can i reuse the head gasket? It looked like there was a new 1 just put in. and then the next thing had me thinking... when i split the case, there was no gasket. looked like there might have been a small bead of sealer, otherwise metal to metal. Normal??? also the upper part of the lower unit had no gasket and it was metal to metal. Normal??? In the diagram for this motor it does not show any gaskets for these 2 places. I want this motor as tight as possible. Then in the gear housing, is the rope seal 1 standard size for most outboards cuz there is no part # for this. Otherwise, i got new crank seals, rings, gaskets, impeller, and the impeller plate. when i put it back together, is it possible the timing will be thrown off? And do i adjust that with the points? I marked a few places around the motor so when I put it back together, it should be close to exactly how i took it apart. Any other helpful info on my rebuild would be great!!!! Thanks alot
