68 evinrude 55hp water pump
ozman83
I have a 68 evinrude 55 hp. Not sure if the water pump works or it even has one. Ive owned this moter for 5 years nd it has never spit water. Niether has it ever over heated. It is starting to run alittle ruogh I think due to corroded wires nd due for tune up. Ive heard this engine doesnt have a water pump but it seems farfetched. I also cant find it on the parts list.
Any help will b greatly appreciated
You can occasionally test your overheat warning horn simply by..... having the key in the RUN (on) position (Engine Not Running), then ground out the TAN heat sensor wire that you'll see extending from the cylinder head. The horn should sound and if it does not, find out why as that's the only warning you'll receive before the engine seizes and locks up solid.
The water pump sits directly atop the lower unit. The driveshaft goes right thru the center of it.
There is no actual water telltale outlet on that engine... the majority of the water exits via the propeller.
However, water may exist the exhaust relief holes at times, as follows.
(Exhaust Relief Ports - Exhaust Housing (Inner/Outer)
(J Reeves)
The long housing between the powerhead and the lower unit is called the exhaust housing. There is a inner housing within it that has a heavy duty seal around the bottom of it, or heavy duty seals around a inner extension between the housing and the lower unit.
The red hot exhaust travels down thru that inner tube and out the propeller with a somewhat supply of water to cool the propeller hub. A good amount of water surrounds and fills the space between the outer and inner tube, otherwise the outer housing would get so hot that the paint would burn off.
Some water pumps, for some reason (differing even when new) exert a great amount of water pressure, and if the exhaust housing seals are in perfect condition, the water fills the tube to a point of overflowing.
This brings into play those two holes or slots, whichever the engine might have, at the top rear portion of the exhaust housing just below the powerhead.
Now, if those two holes/slots weren't there, water would continue to flow up into the cylinders. Water not flowing out of those holes is no concern for alarm UNLESS that outer housing suddenly becomes extremely hot..... the warning horn should sound long before that happens.
The main reason for those holes being there (exhaust relief holes) is that when at an idle, there is an extreme amount of resistance encountered by the exhaust trying to escape due the fact that the outlet via the propeller is now blocked by a wall of water. The escape route in this case is for the exhaust to escape out those two holes, otherwise the engine would slow down quite quickly and die. If exhaust cannot escape, air/fuel cannot gain entrance to the engine.
Thanx that helps so much! How would u know if the water pump is still working then? Because if I dont have to I dont want to take the water pump apart or do u recomend a new impeller anyhow?
If you do not know how old the impeller is you must replace it.----Many motors come to grief just because folks want to stretch the life of that part !!
