I have what I think is a 68' 40 HP Johnson. Model # is RD-30 D, serial is J2858470. It doesn't have enough power to get out of its own way. I recently (about 2 years ago, & only 8 trips on the water since) had the ignition & carb professionally rebuilt. It ran phenomenally the first few trips on the water, then degraded a little. After first few trips, motor would run great at idle, in gear, and up to 90% throttle. At wide open, it would suddenly 'stumble' and not produce much power. If I backed off to 90% (estimated) it ran great again. The last trip on the water, it would start & idle fine, and initially ran well up to 90% or so. Then it started to 'stumble' at 1/2 - 3/4 throttle. Luckily we were on our way in off the lake. By the time we got to the dock, it had virtually no power. From idle in-gear to 1/2 throttle it would run ok-ish, but would surge up & then back down on its own. It still starts immediately and idles just fine in neutral.
I have good experience working on auto engines, but I'm completely in the dark on a 2 stroke out board. I REALLY appreciate any help! Thank you in advance.
