67 60hp Evinrude electric
guido2
"Hi, trying to diagnose chargi
"Hi, trying to diagnose charging system. No charge, motor running on battery power only. Does anyone have stator and rectifier specs on this old gem? This is not in any of my manuals. Thanx, Tim"
"Stator, keeping it simple. Un
"Stator, keeping it simple. Unplug stator. Using an ohm meter between the stator wires, there should be a reading, somewhat like a dead short. Now, between either of those wires and ground, there should be absolutely no reading.
The rectifier.... unplug it then........
(Small Rectifier Test)
(J. Reeves)
Remove the rectifier wires from the terminal block. Using a ohm meter, connect the black lead of the ohm meter to the rectifier base (ground), then one by one, connect the red lead of the ohm meter to the yellow, yellow/gray, then the red wire (some rectifiers may also have a fourth yellow/blue wire. If so connect to that also). Now, reverse the ohm meter leads and check those same wires again. You should get a reading in one direction, and none at all in the other direction.
Now, connect the black lead of the ohm meter to the red wire. One by one, connect the red lead of the ohm meter to the yellow, yellow/gray, and if present, the yellow/blue wire. Then reverse the leads, checking the wires again. Once more, you should get a reading in one direction and none in the other.
Note that the reading obtained from the red rectifier wire will be lower then what is obtained from the other wires.
Any deviation from the "Reading", "No Reading" as above indicates a faulty rectifier. Note that a rectifier will not tolerate reverse polarity. Simply touching the battery with the cables in the reverse order or hooking up a battery charger backwards will blow the diodes in the rectifier assy immediately.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
"Thanx Joe, You probably have
"Thanx Joe, You probably have forgotten more than I know. Take care, will give your store a look. Tim"
