seventyfourci
I have what appears to be a 67 v4tl-13a 100 hp with a 66 ignition system with no fire. I am changing engines out and pulled the 67 motor wiring harness and remote and installed the same. The motor was said to be good but has not been used in 5 or 6 years. I did not confirm that it ran prior to changing it out (my mistake). Any help on trouble shooting this problem? Also any common problems with this engine would be nice to know. Any area I need to look into after the engine being down for this long would also be helpful. I did run a compression test prior to swapping engines out and all is well on compression.
