66 johnson 20hp
D
darrell harp
Guest
engine will not run full throt
engine will not run full throtle without the choke on. It runs good at idle to almost half throtle without choke.
"The carburetor is fouled, gum
"The carburetor is fouled, gummed, clogged. Remove, clean, and rebuild the carburetor with a complete carburetor kit."
maybe check fuel pump also cou
maybe check fuel pump also could be weak or bad line may not be pumping enough to the carb
